Your post is now being reviewed and waiting for moderator's approval.
    • 8144
    50% of my posts are still needing approval. No links, or uploads just around two lines of text !
    • 8144
    But this one worked, it makes no sense!
    • tsbservice
      Field tech
      • 8016
      As a test remove your signature.
      • Aneurysm
        Administrator
        • Jan 2005
        • 1079
        I agree, try removing your signature and see what happens.
          • 8144
          I deleted my signature but this issue remains.
          It appears to be a bit intermittent, no real patten to it.
          • luca72
            • Oct 2017
            • 1778
            It happens to me when I correct, I save the post, and I re-edit it because maybe I want to modify it or I noticed a spelling mistake, it seems that between one saving and another there is a timer, a few minutes must necessarily pass, otherwise it makes me same error like to you
            "I'll be back"
              • 23008
              I noticed that too, on edits. If I make a small spell correction then Save, that's when it happens.
                • 16391
                I was having this problem early on but it hasn't happened in long, long time.
                  • 8144
                  Ok, so this is still happening for me. Even when I simply 'like' a post !
