The first copier you serviced
  • Rusty.Harris
    • Jan 2021
    • 621
    These were the first two copiers i worked on in 1981.
    Some were liquid, most were dry toner. Hated that liquid & thermal paper!
    Sharp SF-740 & SF-810. In the past 40+ years, I've worked on:
    Sharp
    Panasonic
    Ricoh
    HP
    Brother
    Epson
    Xerox
    Toshiba
    Still working on Toshiba, HP, Epson, Xerox.
    What were some of the first copiers you worked on?
    • 37319
    Sharp
    Panasonic
    Ricoh
    HP
    Brother
    Epson
    Xerox
    Toshiba
    We sold Sharp about that same time. Do you remember which model used cold pressure fusing where the 2 steel rollers clicked together as the trail edge of the paper exited?
      • 37319
      I started in 1972. I worked on both copiers and dictation equipment. We were a full line Olivetti dealer. We also sold SCM 33 and 44, Apeco, Saxon and Old Town. And yes I did occasional have to repair 3M thermal paper machines. Back then everything except Xerox was liquid. Dispersant and concentrate, some used premix for a starter. Some of the Olivetti models were also avail as coin operated machines which we had in all the county libraries. When the non-Xerox plain paper machine came out we sold the Royal RBC1 under the Apeco in addition to Sharp.
      • Larhal
        • 550
        1974 Started as a Trained Tech with the Xerox 917, 660 plain paper copiers. Was a Xerox tech up to 1988.
        Larhal
        If all else fails read the Service Manual!
        If that fails, meet me at the pub and we will discuss it.
          • 22997
          I guess I'm the baby here. In 1989 I was first trained on the Mita DC1255, but the oldest machines I saw were the Mita 900D, 800D, ... zinc oxide paper that wrinkled and yellowed, and went blank after a few years. I had (6) of those 900D's at home that I swapped parts around, until I didn't have a usable registration roller any more. Then I scrapped the whole lot of them. There for a while customers would open up a closet to show me a 900D: "Hey do you want this thing? It weighs a ton!"
          • Calva70
            • Apr 2021
            • 23
            I first worked on a Savin copier in 1993 while I was in the Navy, can't remember the model. Then in 1996 while still in the Navy I worked on a Xerox machine on the ship, also not sure of the model but I think it was a 1060 or something like that. If anyone knows anything about the SSRE (Shipboard Service Reprographic Equipment) program the Navy had the Savin was a Class II at the time and the Xerox was a Class III. Didn't touch copiers after 1997 till 2013 when I got a job working for Xerox, and mostly worked on WC 56XX 57XX 58XX, plus a little Altalink B80XX. Then shifted jobs and was more SFPs and MFPs. Now on to Canon, Sharp and HP copiers as well as HP SFP and MFPs.
            • kingarthur
              • 1325
              Mine was the Sharp SF-750. Was the SF-810 the one that used to "talk" . We had to turn it off on the only one we had - it annoyed the customer. One thing I remember about the SF-750, apart from the corona units being a PIA to restring, the corona units had a black coating inside, one of my colleagues was told to clean and rewire it - he was really pleased with himself - when he'd cleaned off the black coating....
              • Saturn
                • Nov 2023
                • 171
                Canon NP 50 and NP 200 in 1979/80
                I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
                • Rusty.Harris
                  • Jan 2021
                  • 621
                  SF-301 had the "crush" rollers as I remember. Hated those things!
                  • Rusty.Harris
                    • Jan 2021
                    • 621
                    LOL, I used a couple bottles of clear dispersant to get me down the road once because I thought I didn't have enough gas in my service van.
                      • 37319
                      Never tried that but did make a good weed killer.
                      • Hansoon
                        • Sep 2007
                        • 3374
                        1st machine I serviced doing a side job being a student, was a Renker Safir EP-404. Came on the market in 1970...... 😮 (YES! I'm THAT old!)
                        A ZnO coated roll paper machine using dispersant with added liquid toner concentrate. The machine was based on an American copier with the brand name VOSS.
                        Hans
                        • Madnhain
                          • Dec 2012
                          • 148
                          I got a late start in the game. My first was a Sharp AR-150. Worked with Sharp all the way up through Polaris. Now I am almost exclusively KM and HP.
                          • kingarthur
                            • 1325
                            I remember the AR-150, had a customer who had a black line down the page, when scanning from the glass, found a massive dead fly against the lamp - no idea how it got in there
                              • 22997
                              I continued to use Dispersant as a cleaning solvent for a decade afterwards. When I could not find it anymore, I switched to paraffin lamp oil. It's just as good and does not damage drum surfaces, just a little oily.
