Please see the following pdf for one way bearings facts. especially item number 4. grease. look at the diagram and the functional description of how the bearing work. see also the lifespan of a typical bearing.
ONE WAY BEARING FACT
Re: ONE WAY BEARING FACT
Interesting. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Always wondered what makes those pins lock one way. Had my theory confirmed. Ever looked inside a magnetic torque limiter?jesus loves you! (everyone else thinks you're an assh*le)
street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trainedComment
Even before i saw that pdf, i had to know how that one way worked. So i took one from a feed roller and sliced it in half and looked at it, saw the spring, which really is a high tension piece of metal bent in a z pattern and the key was to take my magnifier 10x and looked closer at the housing to see the cavity .THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
A magnetic torque limiter is just a cylindrical magnet within a cylindrical magnet, with ferrite powder (developer) in-between. The amount of ferrite is critical, so if you notice that the housing is cracked and it's losing ferrite, it's a really good time to replace it. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Those magnets are pretty strong, too. I stuck one on the luggage rack of the car I was using for work a while back. It stayed there for several years until I apparently blew it off with the high pressure wand at the car wash.Comment
Actually, I've seen ones that were just a magnetic core inside a steel ring. They are used by Ricoh in the ADF separation area at least. The same rules apply though. If the plastic housing is cracked, the steel ring is not fixed to it and will slip.
You are correct. The kyocera 420i and other adf use the type of torque limiter inside the separation roller.The outer case crack as you mention also and the magnet is good strong too. i use them in my screw tray when removing parts. good catch there Iowatech.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
