Asking for the best copy machine type - NEED HELP
  • allan
    replied
    Re: Asking for the best copy machine type - NEED HELP
    In you case i would not make financial sense to buy a new machine see if there is a company that would be willing to rent out a second hand machine on a cost per copy basis.
  • Jaycat718
    replied
    If it's less than 1,000 copies a month, i would recommend the following:
    Canon C3330I
    Canon C5255 (although might be a bit overkill for 1,00 pages a month)
    You can buy a wireless connectivity kit for any machine and turn it wireless. I have set about a dozen of these up. They're inexpensive. Buying a copier with wireless already built in, is going to raise the price Significantly.
    This route will save you ALOT of money. The c5255 will need an additional fax kit installed; whereas the c3330i comes with fax built in. For your low volume the c3330i will serve the purpose you need, bundled with the added Wireless Adapter.
  • Tonerbomb
    replied
    you can make any non wireless copier wireless if it has a wired network port by using a wireless adapter from say netgear or linksys. You don't have to pay big bucks for an OEM wireless kit...........
  • A.A.S
    Guest replied
    Thanks for replying ...
    It will be low volume / less than 1,000 copies/mo.
    Our requirements:
    -Paper size: A3, A4
    -Fax
    -Scan
    -Wireless
  • Jaycat718
    replied
    When you say "we won't be using it that much". What is the total estimated monthly volume for the machine?
  • A.A.S
    started a topic Asking for the best copy machine type - NEED HELP
