Hello,
there is a problem with the shared PS Driver installed on a Win 2012 Server.
I can't use the watermark function of the driver when i add the shared driver
on a client, I can't checkmark it, it remains grey.On the server itself it's available.
Driver dialogue says function can't be used under this configuration.
If I install the PS Driver (newest version 5.1.2.0 is used, older had the same problem)
locally on the client, it works.
There is no problem with the PCL Driver under this configuration, watermark function
can be used on the clients too.
I've tried the same with a Win 2008 R2 Server and a Win 7 64b client and the PS Driver.
There is no problem too.
Someone told me this is a microsoft related problem and you can change something in
the registry of the 2012 server to get this working but had no more information.
Can someone help me?
Thank you
Thank you
