Toshiba e-250 scanner feature goes to"Local Device is Busy"
  • Claudio
    • Feb 2007
    • 235
    Question:
    I'm still messing with this e-250.
    I have been able to hook up the printer (network) & scanner (parallel) on the e-250 copier. Also has the fax modem.
    All works ok, but after a while, when attamting to scan again, the device shows as "Local Device is Busy" and I also get messages showing "failed to connect". It's probably the 4th or 5th time this has happenned. Then to make it work again I delete the software and reinstall it ( Viewer then service pack 1 ) but then will work for a little while then drop out again.
    Initially I had installed the service pack 6 after service pack 1 but I am not installing service pack 6 because it may not apply to the e250.
    I am following the installation instructions from it's pdf file.
    from the "Unimessage Pro" the device is not logged on & when attempting to "Start" it, it does not go green. Has anyone been here before and what did you do to fix this?
    I'm using XP operating system and this happens even with the firewall completely off.
    Thanks in advance.
    Claudio
