HI! When I scan documents using the top feed, the second page get stuck about half way through and the scan is stopped, or scanned documneds are send very slow. The network connection is with cable and speed is good. With printing there is no problem and scan via USB speed is good. I scanned with two different software and the result is the same. I haven't updated the machine, could that be the problem?
canon IR 1643iF ii scano to pc from network
Tags: None
Are you scanning via USB or LAN ?
If copies run through at normal speed but it is only scans that are slow I would try updating the firmware.
www.printerfirmware.co.uk
Thanks guys! I did a factory reset, updated the firmware and everything was fine. Scan through LAN.
