print error to km c350 from mac os x
  • dsb_colorado
    print error to km c350 from mac os x (also posted in connectivity)
    when in send files from my ibook
    i am getting a "printer is busy, will retry in 10 seconds"
    i have tried multiple drivers - downloaded installed and deleted several
    and account settings - which work from the pc's on the network
    this is the only mac trying to access the printer - all others pc and all others work fine once drivers are installed and passwords assigned
    possible problems:
    i think it is a mac in a windows environment issue, or an account security setting
    do i have to install from a CD
    i am doing so wirelessly -
    our network is both wired and wireless so i can go either way
    some setting somewhere
    i noticed that apple talk is set to off on the print out of the printer specs
    thanks
    david
  • dsb_colorado
    solved
    settings:
    protocol: LPD not IPP
    queue : specified as "print"
    use fiery driver: Fiery X3e
    thanks
    • cboucher
      • Jan 2025
      Does this machine have a Fiery controller installed?
      • nightshade
        Chromographic Supremesist
        • 158
        Try loading command workstation if you don't have it already on.
