Hey guys, just wanted to see if there was anyone out there that had more experience working with Novell in a scan environment than I. And I'm willing to bank that there is... I have very very little!!
About a month ago, this customer could browse their Novell tree, then all of a sudden they couldn't connect with it from the MFP. When setting up a folder - they can either enter a path manually and press "Connection Test" to test the connection or press the "Browse" to find the folder they want to connect with. Both fail to connect and we triple checked the path when manually entering it.
So, what I did was set up a small 5 port hub and connected my laptop. Then ran a capture, using Wire Shark, and pressed the "Browse" button. I also ran and saved a separate capture using the Connection Test button. After filtering out the IP of the MFP, we found that the IP for the destination was a multi-cast address (224.0.1.22) using a Protocol SRVLOC.
I did some research this afternoon and found a lot of good info on the Novell site, as well as Cisco. But my question is, why would the machine point to this address? What in the hell is happening here?
