I have a Ricoh Image Scanner IS200e. It use to work perfectly fine until recently. It is connected to my wireless router, Netgear WNDR4500,. My problem is when I go to scan and finish it hangs. So I have to shut if off and on and try again. Sometimes it works and sometimes it doesn't so I just reboot my whole system. Shutting down the moden (cable), and my netgear. Then it sometimes works.
So IS the problem my router and I need a new one or the scanner? What can I possibly check and do to make it work again?
(I apologize if my thread is in the wrong place)
Thank you for any and all help.
