Hi guys,
I have an Ecosys P2040dw on the bench that is dead. No power. Won't power on. I've tried a good AC cable, checked input voltage to the low voltage pwb, and checked continuity on the wire harness to the switch. I'm just before moving on to checking continuity between the low voltage pwb and the main/engine pwb.
Has anyone experienced this same issue with this same model?
Thanks!
Thanks!
