Does anyone have a suggestion for a multimeter lead connector type for testing male pins on a logic or system board? I have the typical leads and smaller leads but was wondering if there is a lead that is insulated and can actually insert all the way to the connector base to reduce shorting out boards and small enough to fit two leads that may be close in proximity again without frying anything.
Pin voltage testing on boards
Re: Pin voltage testing on boards
My suggestion would be to buy a logic probe.
Klein Tools VDV500-123 Cable Tracer Probe-Pro Tracing Probe with Replaceable Non-Metallic, Conductive Tip and a Light for Use in Dark Spaces - - Amazon.comAdversity temporarily visits a strong man but stays with the weak for a lifetime. -
Does anyone have a suggestion for a multimeter lead connector type for testing male pins on a logic or system board? I have the typical leads and smaller leads but was wondering if there is a lead that is insulated and can actually insert all the way to the connector base to reduce shorting out boards and small enough to fit two leads that may be close in proximity again without frying anything.Last edited by ZOOTECH; 09-13-2021, 08:39 PM."You can't trust your eyes, if your mind is out of focus" --Comment
If you go to Amazon and search needle tip meter leads you will find plenty.Comment
In that situation I'll take two large straight-pins, then shrink-wrap all but 3mm at both ends of the straight-pins. Press the pins into whichever electrical pins you want to read, and use clip leads to connect to the head of the pins. It works better if one of the pins is longer than the other. That way the clips are not at the same height, less likely to touch each other.
This also works in situations where you cannot reach the terminal. The straight-pins will press through the wire insulation for a quick voltage read. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
This also works in situations where you cannot reach the terminal. The straight-pins will press through the wire insulation for a quick voltage read. =^..^=Comment
Many years ago when I was taking an electronics class, we had a logic analyzer that used these type of test clips specifically designed for IC pins. I don't think you can get any better than that for IC pins.
10x/Set 28cm Test Clip Hooks Mini Grabber Jumper Lead Probes For Logic Analyser | eBay
Adversity temporarily visits a strong man but stays with the weak for a lifetime.Comment
