Download mode AL-1661CS
  • draph
    • 132
    Machine displays "Downlode Mode" on display, nothing else. None of the buttons on control panel do anything. I've reset all board connections. Re-installed memory and chip. Nothing works. Has anyone else seen this? Also, this machine is not on a network and has never been connected to a computer for printing. They do not use the fax feature either.
    • 22861
    Most likely, the Start button is stuck down. That is how you enter download mode: Hold Start while powering ON. That also explains why none of the other buttons respond. But check all the buttons. =^..^=
    • draph
      • 132
      No, that was the first thing I tried. All Buttons are good and switches are all functioning properly.
