Drum units remaing life span
  • Gbr
    • Nov 2011
    • 50
    [Misc] Drum units remaing life span
    Hello
    Do you maybe know which is the best way (or if it exists), to determine remaining life span of used e.g. C-EXV-17 drum units.
    On MISC value you can not truly rely, (can you?)
    a BIG thank you!
    • 8132
    Re: Drum units remaing life span
    I've found they do always last past 100% however the black does start to leak at around 150% then this will eventually cause the ITB to slip & cause issues.
    I've had some last 350% & higher, it all depends on the customers expectations & how much colour they're printing.
