e0027-004
  • Mukasa
    • May 2015
    • 178
    [Error Code] e0027-004
    Hi
    I have a canon c5055 color but produces faint black .the rest of the colors are good .First i thought the customer had put in a wrong toner.So i put in a new one but to no yield but latter discoverd that the dispensation system was not working, Now i have a haddle what is the cause of not dispensing .please help.
    But at times the machine gives a code E0027-004
  • rayaeek
    • Apr 2015
    • 15
    Re: e0027-004
    Originally posted by Mukasa
    Hi
    Replace black drum to resolve issue.
    • Mukasa
      • May 2015
      • 178
      Re: e0027-004
      Thank you for the effort
      I tried that before but to no possitive results.
      • rayaeek
        • Apr 2015
        • 15
        Re: e0027-004
        l have had similar error code before and noted the black Dev coupling breakage. Replace the coupler with modified one, you will need a pin through the shaft to lock the coupler.
          • 2621
          Re: e0027-004
          Its the black dev coupling.
          The gear part number is FC8-4338-000.
          • Mukasa
            • May 2015
            • 178
            Re: e0027-004
            Thanks i service the toner hopper resevior and the sensors around it and the machine has improved .
            it can now make good copies without displaying the above error code.
            But copies are a bit faint on the end of one side.
            Are faint towards on the front , hope the faintness will go.
            Mukasa
            Mukasa
            • NetTech
              • Jul 2019
              • 11
              Re: e0027-004
              Hi
              I have a canon c5055 color but produces faint black .the rest of the colors are good .First i thought the customer had put in a wrong toner.So i put in a new one but to no yield but latter discovered that the dispensation system was not working, Now i have a haddle what is the cause of not dispensing .please help.
              I wanted to add to this because I just fixed one that was not a normal solution.
              The most common cause of this problem is the cheap BK colored coupling on the developer unit. Canon issued a new one that attaches with a metal pin, cause they kept breaking.
              The unit I just fixed is old. The solution was this: remove the worn felt/plastic pad on the sub hopper assembly. Where the developer's entry, and the subhopper's exit are. Also, remove the white plastic housing that is on the front of the subhopper's feed screw. Pull from the bottom first, then unclip the top. Vacuum out the clogged toner feed screw. Then reattach.
              The felt/plastic seal on the subhopper's outlet was blocking the toner from entering the developer. The felt/glue had worn out, which caused the seal to slip out of place. The toner was jammed inside the feed screw, keeping it from moving. The seal's removal may cause a leak. I'll update this post if that ends up happening.
