Reboots every 3 minutes. Power light stays on. Replaced ddr, flash drive, network board, and board that network board plugs in to. Assuming that is main controller. Any help would be appreciated
1025IF Rebooting
Re: 1025IF Rebooting
Attached Files -
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Power supply or DC controller PCB?
Also Fax NCU or fax modem can be bad.Practice makes perfect
If you want something done right, you have to do it yourself
Replaced nuclear and fax modem this morning. Haven't tried power supply because it only reboots. Green power light stays on. Isn't the ip board the school controller? No other boards back there
Sent from my iPhone using TapatalkComment
