IR-A-C5255
  • gksapple
    • Apr 2014
    • 116
    [CQ] IR-A-C5255
    Hi
    toner dots(black ,yellow) appearing in the printouts in the new machine (installed 2 days before )[ATTACH=CONFIG]32123[/ATTACH] ,replaced the drum issue resolved but is there anything to solve the issue without replacing .have a look on the attachment
  • teckat
    • 16092
    Re: IR-A-C5255
    Originally posted by gksapple
    Hi
    did their location move on continuous copying
    • gksapple
      • Apr 2014
      • 116
      Re: IR-A-C5255
      first yellow dots appeared so yellow drum replaced ,then next day black dots appeared so black drum replaced but dots are not moving from in its location while making continuous copy or printouts
      • teckat
        • 16092
        Re: IR-A-C5255
        same spot rules out dumping of toner rocks/clumps (from poor toner storage) from hopper/developer.
        did u follow initial install procedure
        try to wiped down the itb drive roller ?
        • gksapple
          • Apr 2014
          • 116
          Re: IR-A-C5255
          inset-ymck is executed then inset 4
          stir-ymck is executed then stir4
          itb init is executed
          then autogradion full adjustment with plain A4 paper
