Canon iR5000
  • luis1984bol
    • Nov 2011
    • 143
    [Misc] Canon iR5000
    Hello friends:
    I have a question. Does the Canon iR5000 allow network downloading (TCP/IP) capability?
    Regards.
  • Helpdeskforum
    • 28
    Re: Canon iR5000
    see other answer
    • spectraindo
      • May 2008
      • 313
      Re: Canon iR5000
      Originally posted by luis1984bol
      Hello friends:
      Regards.
      The Canon iR5000 does not support downloading from the network, only from the parralel printer port.
      • luis1984bol
        • Nov 2011
        • 143
        Re: Canon iR5000
        Thanks my friend!..
        • ernesto
          • Oct 2011
          • 430
          Re: Canon iR5000
          Do you know what the problem can be?
          • charm5496
            • 2387
            Re: Canon iR5000
            What do you mean by "network downloading"?
            Are you attempting to upgrade the firmware?
            Are you attempting to make the machine a network printer?
            Are you attempting to scan to a network folder or e-mail?
            • luis1984bol
              • Nov 2011
              • 143
              Re: Canon iR5000
              Yes, I want to upgrade the firmware.
              • smiley
                • Aug 2008
                • 616
                Re: Canon iR5000
                If the machine is still working i think you can just put it on fix ip using 17 and power on and now you can update the firm ware using network.
                there is no glory without sacrifice
                • luis1984bol
                  • Nov 2011
                  • 143
                  Re: Canon iR5000
                  • charm5496
                    • 2387
                    Re: Canon iR5000
                    upgrading the IR-5000 with the network cable was not very reliable, the recommended method was using a parallel cable or the USB to Parallel cable that Canon sold back in the day. If you are not having an issue or replacing the HDD I would not mess with it.
                    • luis1984bol
                      • Nov 2011
                      • 143
                      Re: Canon iR5000
                      Thanks for your recomendation. Have you had problems upgrading via network?
                      • luis1984bol
                        • Nov 2011
                        • 143
