Canon IR 2545 " The memory is full "
  • Anjaskaseto
    • Nov 2014
    • 55
    Hello....
    I have a machine canon IR 2545 when the print is always the message "The memory is full"
    please anyone can help
  • dan7777
    • Dec 2012
    • 680
    Re: Canon IR 2545 " The memory is full "
    Originally posted by Anjaskaseto
    Hello....
    I had a different model (IR1025) that put everything in memory (scans, copy, everything). Check to see if you need to delete jobs in memory. Doing an all clear on that model fixed it. It clears everything so do a back up if you need to try this.
    • teckat
      • 16092
      Hello....
      If copies & FAX go thru, and issue is with PRINTS only___
      Check that the correct Driver is loaded and being used on the PC by operator.
