Imagepress C800 vs Imagepress C7000vp
  • tinnyjay
    • Oct 2009
    • 650
    Hello!
    I have a dilema!
    Cant choose between these two machines.
    Someone know'em please tell me the goods and the bads.
    The cost, stability, quality etc.
    I know more about C7000vp's cost but dont know enough to chose. Theorically i know them both.
    I need to print business cards, book covers, calendars and many more. Need a 300gsm perfect registration duplex.
    Any help is appreciated.
    Thank you
    "Who loves the roses,must also bear thumbs"
  • Jaycat718
    • Oct 2013
    • 67
    Re: Imagepress C800 vs Imagepress C7000vp
    You will get more Up time from the VP due to part yields. We have about 30 c800's in the field, and about 5 of those are being used for production purposes. We only see the customer for maintenance parts replacements. Drums, Dv's, Rollers, upper/lower fuser belts Etc. The VP's we rarely see. But when we do see them, it because something has gone very wrong!
    From a parts replacement stand point, the C850 would be you best bet. (C850 has replaced the c800). Everything on this unit is pretty simple to replace; pretty similar to the c9000/9200.
    From a parts Yield standpoint the VP would be your best bet. But remember, replacing parts can be a one day job, or a one week job.
    • V-P
      • Apr 2011
      • 679
      Can you compare a bicycle and a motorcycle ?
      • tinnyjay
        • Oct 2009
        • 650
        Thank you...
        You are helpful!
        • teckat
          • 16092
          C800/C700/C600 lets you quicklyand effortlessly produce duplex print jobs on heavy weight media up to 300 gsm, Compact Registration Module delivers with highly accurate front to back registration sheet after sheet.
          don't believe everything printed or u read ----
          these imagePRESS PRODUCTS were/are tested in a perfect environment----& not in the real world.
