Re: Canon IR Advance 6055 damaged web roller
The part # is FC9-8282-000.
But as proposed above, have a look on the Web advance mechanism.
Rachid.
I think ive found the cause of the problem, yesterday after taking the fixing unit apart i noticed a small piece of black plastic caught in all the web.
Its a piece of the web roller feeding flag, does anyone have the part number? its the piece circled in red in the attached image, i cant find it in the service manual i have.Attached FilesLeave a comment:
Is there a way to check that motor in service mode? we'll be going to ser4vice it tomorrow afternoon, we got a new web roller, heat roller.Leave a comment:
So, this machine has torn apart 2 web rollers in less than 2 months, the first one i replaced was like 2 meters deep between the heat and pressure rollers completely torn apart, i replaced it anc cleaned all the mess and it worked just fine for 7 weeks.
Last saturday client reported it was jamming a lot until it eventually stopped printing, oone of my collegues went to service it and the web roller is in 2 pieces again (attached picture), this isnt normal obviously, do you guys have any idea on what should i check for damage or normal wear?
From what i remember, the pressure and heat rollers were all oily, like a LOT but i didnt clean it since i thought this was just normal, my guess is the heat roller needs replacement because i remember it having a toner "stain" i could not remove the first time i serviced this machine and i thought the web roller will take care of it, now im not sure about what should i check first.
Any hint appreciated.Leave a comment:
sounds like the web advance mech isn't working properly.. had this problem with some of the Savin Copiers... found the little motor for the gears was flakey.Leave a comment:
Any hint appreciated.Attached FilesTags: None
