Canon ir avd 8105 e004-0102
  • tinnyjay
    • Oct 2009
    • 663
    Hi!
    When i was changing uppper fuser roller, wrongly i put wire of main thermistor in cleaning web sensor's wire and machine show E004-0102.
    As SM said its a problem on IH POWER SUPPLY PCB ASS'Y.
    I have removed all power supply but cant find by Canon codes which one is the one i need.
    Part codes are different as SM, so i have thesepart numbers in my machine:
    FK27702
    FM4-1086
    FK2-6447
    FK2-7356
    Which one do i have to change or repair.
    Any help i'll appreciate.
    Thank you
    "Who loves the roses,must also bear thumbs"
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: Canon ir avd 8105 e004-0102
    Hi,
    According to your explanation, i would have changed the DC controller PCB.
    The fixing power supply PCB (IH power supply) has the following number: FM4-1092-000.
    Rachid.
    Fixing power supply Position.pdf
    IH POWER SUPPLY PCB ASS'Y.pdf
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • tinnyjay
      • Oct 2009
      • 663
      Originally posted by Rachid.Akli
      Hi,
      Rachid.
      [ATTACH]35937[/ATTACH]
      [ATTACH]35938[/ATTACH]
      There is no board with that part number.
      Therefore i uploaded photos.
      • Rachid.Akli
        • Oct 2011
        • 595
        Hi,
        Part numbers shown on PCBs may be different from the ones of the part catalog. I always take into account the Part catalog.
        Rachid.
        • teckat
          • 16083
          Hi!
          FK27702
          FM4-1086
          FK2-6447
          FK2-7356
          [ATTACH=CONFIG]35932[/ATTACH][ATTACH=CONFIG]35933[/ATTACH][ATTACH=CONFIG]35934[/ATTACH][ATTACH=CONFIG]35935[/ATTACH]
          Thank you
          IH POWER SUPPLY PCB ASS'Y is the (Fixing Power Supply) has Four Connections
          J500 2pin
          J501 #pin
          J502 19pin
          J510 7pin
          Remember to clear the error in Service Mode>COPIER>FUNCTION>CLEAR>ERROR
          see article below------Main Driver PCB was fix
          E004 -0102 = Fixing Power Supply Error
          Remedy = Replace the Fixing Power Supply PCB (PCB10).
          Replace= Main Driver PCB (PCB2).
          Description Fixing current error.
          FM4-1092-000===IH POWER SUPPLY PCB ASS'Y is the (Fixing Power Supply)
          imageRUNNER ADVANCE 8085 / 8095 / 8105 / 8205 / 8285 / 8295
          Title :
          E004-0102 Error Code
          Error :
          After working on the fuser unit, pico fuse FU15 on the Main Driver PCB (PCB 2) keeps blowing and causing error code E004-0102.
          Workaround :
          For this case, connector J3202 for TP1 - Thermal Switch 1 and connector J3207 for PS45 - the Cleaning Web Level Sensor got switched around.
          Connector J3202 is a 3 pin connector but only has two wires. Connector J3207 is also a 3 pin connector which has three wires.
          Once the devices were plugged into the correct connectors of the fuser unit and the Main Driver PCB replaced, =====FM4-1083-000 Main Driver pcb
          the pico fuse FU15 no longer opened up on the Main Driver PCB.
          Refer to illustrations below for further reference;
          • legion1996
            • May 2015
            • 2
            I have this problem un adv8095 .
            • teckat
              • 16083
              See above 😱
              • legion1996
                • May 2015
                • 2
                Originally posted by teckat
                See above 😱
                • teckat
                  • 16083
                  • tinnyjay
                    • Oct 2009
                    • 663
                    [ATTACH=CONFIG]38807[/ATTACH]
                    Teckat, i had to change Dc Controller to fix it.
                    Bye
