White lines on copy
  • rudysemira
    • Oct 2016
    • 108
    White lines on copy
    Anyone encouter this problem for canon 7095, i appreciate to someone who can help me thanks....
  • aandy_py
    • Aug 2015
    • 15
    Re: White lines on copy
    I would suspect primary corona wire/grid, get it out and give it all a good clean.
    • rudysemira
      • Oct 2016
      • 108
      I tried to clean but same problem any suggestion?
      • rudysemira
        • Oct 2016
        • 108
        Do you have any suggestion i tried to clean the grid wire and alao i took to another machine but same problem
        • aandy_py
          • Aug 2015
          • 15
          Hi so you put this corona unit into another machine and got the same problem? If so replace the unit.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Maybe developer? Inspect cylinder.
            • rudysemira
              • Oct 2016
              • 108
              we have one machine ir 105 that is same primary grid wire i tried to install on canon 7095 but the same problem do you think this is related to laser unit?
              • rudysemira
                • Oct 2016
                • 108
                the developer was okay i tried to swap to other machine when you test print page 5 and 6 the result it just like what i have posted here the image attached..do you think possible problem from laser unit? today i am going to comeback to my customer to inspect the laser unit...
                • aandy_py
                  • Aug 2015
                  • 15
                  Hi. In my experience lasers give more refined lines.is the paper damp, or environment damp?
                  • rudysemira
                    • Oct 2016
                    • 108
                    no, as you can see the line is same area when you test print while when you copy and prints that area was blank....
                    • tinnyjay
                      • Oct 2009
                      • 663
                      I would clean mag roller first in developer unit.
                      "Who loves the roses,must also bear thumbs"
                      • rudysemira
                        • Oct 2016
                        • 108
                        thanks to everyone from your suggestion and solution to that problem, Yesterday I finished to solve the problem i manually clean the transfer/separation corona assembly i followed instruction the image formation process....Thanks to all....
                        • rudysemira
                          • Oct 2016
                          • 108
                          It would help to anyone who encounter this problem in the future.........
