Canon image press c-1 error code e0009-0001
  • ICEMAN
    • 29
    Can any one tell me what this error code is and how to fix this e0009-0001
  • Paul 75
    • Oct 2008
    • 97
    Iceman, check the decurler unit.Has it been taken off for any reason, or check the connections into m/c. This has to be on the machine for it to work.
    Oh...... I can't copy at the moment then ? !!!!!!
    • Starion
      Tech
      • Jul 2008
      • 58
      E009 Error in relation with power supply
      0001 Error in detecting 24V connection of decurler
      Check the sub power supply code and the decurler's power supply
      The decurler unit has 2 plugs and an earth wire which plug in behind a small panel just to the rear of the decurler. make sure these have been plugged back in if its been removed.. otherwise you may need to look deeper at the power supply
