Canon ir adv 8105 e824-000
  • tinnyjay
    • Oct 2009
    • 663
    Hi.
    I know there is FM2, but changed the fan and still code is remaining.
    In pcb2 its connected to J130 and i want to know if i can change any relay that affects FM2.
    Thank you
    Forget it...solved!
    "Who loves the roses,must also bear thumbs"
  • apollo
    • Mar 2008
    • 182
    Re: Canon ir adv 8105 e824-000
    Hi
    would be nice to share you results on with forum members
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5013
      He probably missed something obvious.
      • tinnyjay
        • Oct 2009
        • 663
        Originally posted by apollo
        Hi
        Yes, you are right. I am sorry. It was more necessary to fix it at the time and i did it.
        It started with a pre-transfer corona problem and after that i cutted 3 wires of developing/corona fans.
        I forgot the copier was on (my bad) and trying to connect the wires i just made a short circuit
        And E0824-000 was persistent. And through service manual i found where the wire go in main board.
        It was J130. Close to J130 were 4 relays and after i tested the relays through a multimeter i found 2 of them dead.
        Were two 1.5 A relays and i had many of them from the old/defected boards. I fixed for 5 mins.
        I never faced problem like this before(with relays), but mainly after a short circuit, its the relay that reacts first. So what i learned from physics is right
        Now its working perfectly!
        BYE
