Canon IR Advance 4035 with E0505-001 error when G1 Staple finisher is plugged in
  • copiertec
    • Jan 2016
    • 2186
    I am currently working on a Canon IR Adv. 4035 that codes out when the G1 staple finisher is plugged into it E0505-0001.
    I don't see much on this error in the service manual. I tried to clear the code by going into service mode function, error, clear reboot mfp but same error E0505-001, I went into connection test in service mode in options and get NG. MFP runs great without the G1 finisher.
    I have ordered the main control board (FM4-8284-000) for the G1 finisher, in hopes that this is where the issue is. Any ideas to resolve this issue?
  • roho
    • Mar 2009
    • 844
    Re: Canon IR Advance 4035 with E0505-001 error when G1 Staple finisher is plugged in
    Try flashing it via usb in download mode with the finisher attached, may be simply firmware.
    • copiertec
      • Jan 2016
      • 2186
      Thanks, but, unfortunately, we do not have access to Canon Firmware.
      • guitar9199
        • Sep 2016
        • 1099
        If the machine is networked...and you can get into Service Mode, you can download the firmware right from the machine.
        • teckat
          • 16083
          May need to re initiliaze the Finisher,
          It's a dip switch procedure, look in manual.
          Print out a P Print before doing.
          Re input Finisher settings
          Also, adjustments for staple position and alignment must be performed to re_avoid an E505 code at power on.
          • copiertec
            • Jan 2016
            • 2186
            It is networked, so I will try the update procedure in service mode.
            • copiertec
              • Jan 2016
              • 2186
              I was wondering about dip switch settings, as these finishers are similar to Sharp finishers. I will look for dip switch procedure in the service manual. What is a P Print? Is it a print out of the current settings?
              • teckat
                • 16083
                Yes current settings, may have some Finisher settings listed
                • copiertec
                  • Jan 2016
                  • 2186
                  I appreciate it; if it not obvious, I don't work on too many Canons, so every little bit helps.
                  • copiertec
                    • Jan 2016
                    • 2186
                    Thank you for the help. I installed a new finisher main control pcb and that wound up fixing the issue. However, I did try to update the firmware and try some dip switch settings before installing the new board but to no avail. I have to admit, guitar 9199, that is one of the easier firmware updates, I have done, thank you. I was a little reluctant to update it, at first, but appreciate the help.
