Canon DR-9050C image FORMULA Scanner USB to network ? scan server/ print server
  • tonerjockey
    • Apr 2014
    • 544
    Hi guys, this unit has a USB and SCSI port on the back.
    the customer wants it to be network. they don't use a server i don't believe, and i think all their computers are PC.
    but they have several computers in the office that they would like to scan with it.
    does anyone know if the USB print server would be the link that would allow this?? i did see some software that would allow it.
    any input would be greatly appreciated.
    Have a great weekend, Jim
  • teckat
    • 16092
    Re: Canon DR-9050C image FORMULA Scanner USB to network ? scan server/ print server
    What SCSI Cable is used for the DR9050C Series?
    Answer :
    You will need a SCSI cable that is compatable with D-Sub, half-pitch, 50 pin connector.
    How do you install the DR 6050C / 7550 / 9050C in a SCSI Daisy Chain?
    Answer :
    Because the Scanner's termination is permanently set to ON you would need to install the Scanner as the last device on the SCSI chain
    USB is High Speed 2.0
    USB HUB
    DR 9050C
    User Manual, if needed ��
    • tonerjockey
      • Apr 2014
      • 544
      would a USB print server work to convert the USB to network?
