Canon iR 2520 paper jam when printing 2 sided
  • darkocg88
    • Jan 2018
    • 63
    [Jamming] Canon iR 2520 paper jam when printing 2 sided
    Basically, the problem exists only when printing 2 sided. One sided goes without any issues.
    Strange thing is, it doesnt report any error for a while after it gets stuck, copier appears like it's printing but no paper comes out printed due paper being stuck but no error report.
    Picture of where paper gets stuck in attachment.
    Thanks for help in advance
  • Brian8506
    • 1614
    Re: Canon iR 2520 paper jam when printing 2 sided
    Need the jam code but that sensor flag in the picture is a good place to start. That trips a sensor in that assembly that may be dirty. I have had that on the 3225 series. I believe the sensor is at the rear side.
    • darkocg88
      • Jan 2018
      • 63
      There's no error code, paper just gets stuck, copier works like its printing, and after few minutes it reports paper jam. I reassembled whole copier, every and any tiny gear, cleaned it and used contact spray, it appears the problem is solved but I still don't know what the problem was
      Sent from my Moto E (4) Plus using Tapatalk
      • Brian8506
        • 1614
        I never liked that service mode. You can print a history out that gives you X # of jams and errors. That's where the jam codes are.
        • livancicm
          • Sep 2008
          • 104
          FK2-9154-000 CLUTCH
          • darkocg88
            • Jan 2018
            • 63
            We're still talking about 2520? History after machine was last restarted? Pretty sure the only code I'd get is something related to duplex. Can you please specify which report are you thinking of, thanks
            • Brian8506
              • 1614
              Service mode/report/error log list and print it out
              • Ashlen21
                • Oct 2017
                • 3
                Originally posted by livancicm
                FK2-9154-000 CLUTCH
                Hi guys which clutch is this canon ir 2525 keeps jamming on duplex printing
                • Brian8506
                  • 1614
                  • Ashlen21
                    • Oct 2017
                    • 3
                    [QUOTE=Brian8506;1523771]
                    • nicknt82
                      • Nov 2011
                      • 100
                      Replace Duplex Clutch will solve this
                        • 22809
                        good job grave digger this thread has been dead since 2018
