Have never seen this before. Copier folds over one corner. Only when doing double sided with heavier paper.
I replaced the fixing assembly and it stopped. Customer called back today and said it's doing it again. It only does
it on one or two out of 20 pages so trying to force stop it was not a good option. Double sided on 20lb paper had
no folded corners. I tried a different inner finisher before trying the fuser and that made no difference. Just
checking to see if anyone has had this on these models. I have never seen this before. Very few of our customers
run heavier paper double sided. This isn't real heavy paper. 24 lb I think. It is not a wrinkle its a perfect corner
fold. It is on the back side of the machine. I am going to have the customer run that paper in the letter R direction
to see what happens. Has to be something in the duplex paper path but I couldn't see anything.
