Canon IRA C5045 uploading color profiles.
  • tinnyjay
    • Oct 2009
    • 647
    Hi
    Printing from PS driver i can choose a cmyk or rgb profile (for example JAPAN 2001).
    Is there any way to upload a new profile (Fogra 39) to the printer?
    Byee
    "Who loves the roses,must also bear thumbs"
  • guitar9199
    • Sep 2016
    • 1097
    Re: Canon IRA C5045 uploading color profiles.
    You'd be uploading the profile to the computer....not the printer.
    Here's some light reading for you....
    Canon DLC: Article: Integrating Third-Party ICC Profiles into Your Printing Workflow
    • tinnyjay
      • Oct 2009
      • 647
      Its a PS3 installed and i dont mean cmyk profiles to simulate the workflow, but the printer.
      For example Japan 2001 its a cmyk profile installed in printer.
      • guitar9199
        • Sep 2016
        • 1097
        How to Install ICC Printer Color Profiles
        • tinnyjay
          • Oct 2009
          • 647
          Hi
          I think you do not understand what i need.
          Thank you
            • 22808
            Originally posted by tinnyjay
            Hi
            Thank you
            NO...it sounds like you do not understand how to phrase your request for help.
            • tinnyjay
              • Oct 2009
              • 647
              Printer, since has a postscript installed, has also some cmyk profiles related to the postscript and installed inside printer system or hard disk.
              I am searching for a way to upload new cmyk profiles to the printer.
              Installing new cmyk or rgb to computer is the simplest way since you can double click to downloaded profile.
              I need pro level help!
              • disamm
                • Oct 2018
                • 59
                Try this. it is not longer supported by canon, but it works.
                1. Download the NetSpot Resource Downloader and install it: https://d2.driverscollection.com/-42...96/n673enx.exe
                2. then on the device, change the SNMP settings, from Read to Read/Write. Also change the Community Name 2 to „canon_user“, reboot the device.
                3. After this start "run as Administrator" the Netspot, whait, check if "Color" ist selected and not "Font Macro", search the device and add the device to the right Profile on the left, select the color profile and send it to the device.
                after this, you can select the Profile on the device.
                • tinnyjay
                  • Oct 2009
                  • 647
                  It wont work...
                  The only way is to install a fiery controller.
                  Thanks by the way
                  • disamm
                    • Oct 2018
                    • 59
                    It wont work...
                    Thanks by the way
                    can you upload the profile?
                    with my device it works, SNMP Red/Write without this "change the Community Name 2 to „canon_user“, is not needed.
                    Then go to the tool (Netspot…), start it, register the device and add it to the CMYK Simulation Profile, select the icc profiel, and send it to the device. After this, open the RUI - Printer - PS - and then you can select the icc.
