Problem Finisher N1 Canon ADV 8205
  • Robert Silva
    • Jan 2019
    • 35
    Hello.
    I have a Canon NV Finisher ADV 8205 that delivers all the disorganized sheets. There is no error code or congestion. I point out that the problem is not in the processing area. I had the opportunity to put in another processing unit and the problem persisted. Can anyone give me a light? Thank you in advance for your attention and effort.
  • bobburnsreb
    • Mar 2015
    • 228
    Re: Problem Finisher N1 Canon ADV 8205
    Try this::
    RTNRL-SP Adj Return Roller rotation speed: Fin-N1Lv.1 Details To adjust the Return Roller rotation speed.As the value is incremented by 1, the delivery speed is increased by50 mm/sec.Use case When alignment condition is poorAdj/set/operate method 1) Enter the setting value, and then press OK key.2) Turn OFF/ON the main power switch.Display/adj/set range -6 to 0Unit 50mm/s
    Default value 0
    0 Kudos
    Reply
    • Robert Silva
      • Jan 2019
      • 35
      Thanks for your suggestion, bobburnsreb. I'll try to get results with your tip. Other than that, I'm somewhat convinced that the problem must be mechanical and physical, because the machine works perfectly in 70% of its use. The defect (the other 30%) has been intermittent. Usually the fault occurs after the machine has been idle.
      • Robert Silva
        • Jan 2019
        • 35
        I still can not solve the problem. I noticed that in A4-R the defect does not occur, but A4 does. The suggestion of the return roller had no effect. Many thanks to all for your attention and suggestions.
        • hidius
          • Jun 2015
          • 128
          check the swing guide for anything thats broken .. i had to replace a swing guide to fix the same issue as what your having .. as you can see from the picture it had a broken cover and the white slider roller kept flapping around causing the paper to not be pulled back into the process tray properly and skewing the paper
