Re: Canon iR2545
You hold down the 2&8 keys while turning the machine on and wait for it to go into download mode...
Canon iR2545
Re: Canon iR2545
Hello All
I have a problem with Canon IR2545,
when the engine is turn on from the main switch, the engine does not respond to anything, only the power light is on. the engine will run after pressing the ON button in the control panel. even then the machine cannot be ready, only displays the progress bar. how to solve problems like this?
Clean RAM or replace new RAM. If's not solve, replace new Maincontroller PCBLeave a comment:
Re: Canon iR2545
Do you have a hard drive and system software to reload?Leave a comment:
Re: Canon iR2545
Did you try putting in another hard drive from a good machine?Leave a comment:
Guest repliedRe: Canon iR2545
have you clean RAM and ROM yet?Leave a comment:
Canon iR2545
Hello All
