Canon iR2520 will not print over network
  • a9651
    replied
    Re: Canon iR2520 will not print over network
    您可以尝试将打印机与电脑,用网线直接连接起来,打印机与电脑使用固定ip地址,然后打印测试 。
  • Arcadian
    replied
    Originally posted by Jama
    For windows 10, have had same problem, will be waiting for updates, tried all drivers but nothing happens, even simple USB cant plug and play>>
    i would do a firmware update on the printer seems like a protocol issue, try accessing the printer thru a browser, or maybe just use a laserjet iii driver to see if that works.
    or do a cold reset, im sure the ip protocols are screwed up
    if you cannot access the printer thru network, then maybe the ip has changed
  • Jama
    replied
    Originally posted by edinh
    I have a huge problem with our Canon ImageRunner iR2520. It is installed as network printer a normally prints on my old Lenovo laptop with Windows 7 Pro 32bit sistem. But on other PC with installed Windows 10 1809 x64 there is no way I can make it to print anything, sometimes not even an internal testpage. Occasionally it does print some Word or Excel document but no chance to print PDF. But it only rarely prints something in Windows 10.
    Have tried everything. Installed UFRII LT drivers (newest and older versions), have tried PCL drivers, tried to send data as RAW data and as LPR but nothing helped. Installed it as normal network printer using Standard TCP/IP port and WSD port, but to no avail. Network communication works normally and I can ping and communicate with the printer. I can normally configure it through an internal webserver. Printer has static IP address.
    When I send some print job to the printer it beeps as everything printed OK but nothing actually comes out. The second I send the print job it instantly beeps as if the job was finished but nothing prints, no paper comes out. And in printer log file it states that everything went OK, no error. Only in some cases it throws an error NG(#853), but rarely.
    I don't know what to try else. I think it is possible that there is some incompatibility with newest Windows 10 1809 revision, because just a few weeks ago everything worked OK on an older Windows 10 revision 1803. And then suddenly it just stopped. I think that after Windows update the problems started.
    Can anyone help, any advice is appreciated.
    Thanks!!!
  • Jama
    replied
  • q555
    replied
    Try resetting the printer to factory defaults and update it's firmware
  • edinh
    replied
    Originally posted by demonical
    there is a problem with the latest version of the official drivers.
    just download and install this one
    GUFRII_Driver_V220_W64_uk_EN_02
    hope this helped!
    Thanks for Your help. Next time I encounter the same problem, I will try with the driver You mentioned.
  • KenB
    replied
    hope this helped!
    About 9 months too late.
  • demonical
    Guest replied
    I verified the driver and it is for ImageRunner 2520 not for the Advance series. Thank you for the PCL/PostScript information, I didn't know that. I once even tried with the PCL driver and naturally it didn't work because we do not have a license. Thank You!
    hope this helped!
  • edinh
    replied
    Originally posted by guitar9199
    Verify that the version of UFR II is for that model. ImageRUNNER and ImageRUNNER Advance use a different version of that driver.
    PCL/PostScript won't work if the customer didn't order it. It's a license on the machine that needs to be enabled in order to work.
    If you click the "Print" button, and then the data light flashes once... and goes off, they don't have the PCL or PS on that box.
  • edinh
    replied
    Originally posted by Scottb
    a lot of times win 10 boxes will manage your printers and change the port automatically. We have had several accounts call in and not be able to print all of a sudden. When the port was checked it was changed from the IP address to a WSD address and was showing offline. I changed the port back to the IP address and set that printer as the default, so far all have been printing without any other issues.
    I will check and try your suggestion. Thank you very much!
  • edinh
    replied
    Originally posted by Arcadian
    check to see if your new pc is talking thru the network, a anti virus program or anti-malware program could be blocking the port to the printer, try pinging it. i doubt its a driver issue.
    sounds more like a windows issue.
    Thanks for the suggestion. PC is talking without problems with the printer and pinging it OK. I tried to disable the firewall and still the problem remains. I too think that it is most probably a Windows 10 issue and not the driver issue because the same driver works OK on my much older Windows 7 PC.
  • edinh
    replied
    Originally posted by nicknt82
    I think that just wrong driver. Find correct driver : UFRII windows 10 64 bit. (don't use 32bit )
    #853
    Cause 1
    The job could not be executed when you tried to print a large number of pages on the printer, due to
    insufficient resources.
    Remedy
    Reduce the number of pages to print, or execute the job again when there are no other reserved
    print jobs.
    Cause 2
    When sending print data to the machine from a computer, the job could not be executed because it
    was canceled from the printer driver.
    Remedy Perform the operation again.
    Cause 3
    The spool region for the received data became full and all the data from the host could not be
    spooled with [Use Spool Function] set to 'On' in [Network Settings] in [Preferences]
    (Settings/Registration).
    Remedy
    Set [Use Spool Function] to 'Off' in [Network Settings] in [Preferences] (Settings/Registration), and
    perform the operation again. (See "Communication Environment Setup.")
    Cause 4 The maximum received data size was exceeded when processing the received data.
    Remedy
    Perform printing again when all the jobs are complete. If you still cannot perform printing, check the
    sent data.
    Thanks for your suggestion but I am using the UFRII Windows 10 64 bit driver. Tried several of these drivers, new ones and older ones and still the problem remains. I could try the Remedy 3 to turn off the "Use Spool Function" in Network settings of the Canon printer but than again could that be problem if I only send one Word page or just one plain pdf page to the printer and it doesn't print. I cannot imagine that one small document of just one or two pages could be that much of a burden to the spooler. Thank you for you help!
  • edinh
    replied
    Originally posted by zoraldinho
    Any updates?
    Sorry, I didn't manage to try your solutions. I definitely will. Colleague who is having these problems with Canon printer somehow manages to occasionally print on this printer. Sometimes it works for a few pages and then again stops. Gonna try your solution in the following days.
    Thanks!
  • guitar9199
    replied
  • Scottb
    replied
