Print Margins Imagepress C800
  • ipicopier
    • Jun 2018
    • 21
    Hi,
    Working with a image press c800 and the print margins on the spec sheet say this:
    But when I print my margins seem a lot larger, i already checked the lead and trail edge and image is centered and even. The large margins is out of all the trays.
    Is there a way to change the print margins?
    Thanks!
  • teckat
    • 16083
    Re: Print Margins Imagepress C800
    Originally posted by ipicopier
    Hi,
    [ATTACH=CONFIG]42774[/ATTACH]
    Thanks!
    check User Manual
    too many adjustments tor listing
    https://oip.manual.canon/USRMA-0058-zz-PS-enUV/frame_htmls/home.html
    Adjusting Lead Edge Alignment of the Image
    • ipicopier
      • Jun 2018
      • 21
      Yes, i did look at the lead edge and that's ok.
      The margin i'm talking about is the print margin the machine takes when printing.
      I'm sure this is just a default setting but my c800 is taking a larger print margin.
      • bobburnsreb
        • Mar 2015
        • 228
        Look at image position adjustment under installation of the machine in the service manual.
        • ipicopier
          • Jun 2018
          • 21
          thanks, i looked at that and did a test print.
          See the black image the test print is correct and the margins are to specs.
          But when i print out of any tray i get a larger margin - see the yellow print out
          Is there a global change for this, don't know why its printing like that..Thanks
            • 22946
            Is your print driver defaulted to "Fit Image"? A standard LTR image will be reduced ~96% when sent as "Fit ...". If you want exactly the same size select "Same size as original" or 100%. =^..^=
            • teckat
              • 16083
              [ATTACH=CONFIG]42781[/ATTACH][ATTACH=CONFIG]42782[/ATTACH]
              Your non - image areas are different than your leading edge_trail edge
              • ipicopier
                • Jun 2018
                • 21
                I checked the driver and its set to print at 100%
                "Your non - image areas are different than your leading edge_trail edge" - But is this a global setting in service mode?
                • teckat
                  • 16083
                  Service Manual
                  Adjustments
                  page 986/7 > 1071 = 85 pages of situations to check
                  starts with
                  BASIC -47 pages
                  When Replacing Parts- 37 pages
                  When Clearing Ram- 1 page
                  i would look at Basic -- grab a six pak/ find a lounge chair
                  • ipicopier
                    • Jun 2018
                    • 21
                    so i printed a sheet from the glass, and the margins come out correct.
                    So i checked the fiery, to see if there was a setting increasing the margins but no luck..
                    But seems like the printing from the fiery is increasing the margins strange..
                    we are using the G100 server..
                    Thanks for all the info..
                    • ipicopier
                      • Jun 2018
                      • 21
                      Could anyone do me a favor and if have a g100 or f200 server could you print a full bleed image from and see if the margins are bigger like my sample.
                      thank you!
                      • ipicopier
                        • Jun 2018
                        • 21
                        thank you!
                        [ATTACH=CONFIG]42949[/ATTACH]
                        Just reaching back out to anyone who could run a test print for me..thanks!
