Re: Late Printing Canon IR3300
Hard Drive if Fine
Solid State Drive
SSD
the problem was with
Power Unit
i replaced it
now the OLD machine is working fine
anyway thanks for the post
Guest replied -
Wow this is an old machine!
Sounds like the HDD is failingLeave a comment:
Guest repliedRe: Late Printing Canon IR3300
i am using Canon IR 3300 photocopier machine
every day after i start the power button, my machine does not print any page
photocopy, print given from computer or even any document saved in its mailbox
but it starts printing without any problem after some time
nearly after 45-50 minutes
suddenly, some times when i give multiple prints it prints page half then remaining all copies blank after that,
i have to wait for some time to start the prints again
for eg:- if i give 12 pages print, then it might print 4 pages correctly and 5th page half and remaining 6 to 12 pages blank
what may be the problem
what should i check
thanks for the support
i had replaced nearly every thing with other two same machines
i replaced Drum unit, developer unit, HDD with other unit
but all were acting same
all works perfect on the other machines
finally when i replaced the power supply it started printing
and when i tried my power supply (Defective) on other machine
that machine started delivering BLANK COPIES
so i concluded on FAULTY POWER SUPPLY
Friends thanks for the support,
if any one faces a such problem
may use this to try solving their problemLeave a comment:
Hard drive could be going out. Replace and reload system software.Leave a comment:
what should i check
