Canon imageCLASS MF6540 intermittant blank pages
  • copyaction
    • Oct 2007
    • 991
    Old Ricoh guy here with no experience on these looking at my customers home machine.
    Running say 10 pages through the doc feeder maybe 4 or 5 come out blank. No misfeeds, just blank pages.
    Even if I run just 2 pages, 1st is fine and 2nd is blank.
    Tried running from glass and unable to duplicate problem.
    Tried new OEM cartridge and also forcing laser shield held open.
    Open to any ideas, thanks
  • duxxa
    • Sep 2020
    • 5
    Re: Canon imageCLASS MF6540 intermittant blank pages
    Feed solenoid might be sticking causing it to feed multiple pages per scan, or try checking the drum contacts.
    • copyaction
      • Oct 2007
      • 991
      Thanks for the response. I had considered multi feeding but I ran many sets with only 2 originals and could see them coming out one at a time with the second page blank.
      I will check the drum contacts when I go back.
      • rapidocument
        Multibrands Tech
        • Jul 2012
        • 381
        check your pm
        My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
        • ernesto
          • Oct 2011
          • 430
          when you are printing it is work, the problem is in the feeder, this is not uncommon in this model and ir 1024 series 90 per cent sure is the two feeder solenoids
          • duxxa
            • Sep 2020
            • 5
            Any updates on the issue?
            • copyaction
              • Oct 2007
              • 991
