Ir2530 Duplex Jamming Code 010D
  • oombees
    • Apr 2016
    • 27
    [Jamming] Ir2530 Duplex Jamming Code 010D
    Hi All
    I have a problem with a Canon iR2530 jamming on duplex. The error log states 010D, 0101 and 0108 but what happens is very strange. The paper will go back into the machine from 2 way unit to print 2nd side but the page will get stuck in the door and the machine will not display jam immediately. The machine will just run for about 2 mins and then display jam. I have never seen this. I have upgraded firmware but to no avail. Any ideas guys?
  • GIUBOSS
    • 1331
    Re: Ir2530 Duplex Jamming Code 010D
    check sensor actuator if out of position, duplex clutch may also be faulty.
    • nicknt82
      • Nov 2011
      • 116
      Originally posted by oombees
      Hi All
      Try replace Duplex Clutch
      • oombees
        • Apr 2016
        • 27
        Hi Guys
        I have resolved the issue. The issue was related to the use of wrong printer driver. The client previously used a Ricoh device. I realized the issue was stemming from the driver after I ran 200 2 sided copies with no issues. As soon as client printed the machine went into the jam state. I defaulted client to Canon driver, deleted the Ricoh driver and voila, problem solved.
        Hopes this helps othet techs in future.
        Sent from my MAR-LX1M using Tapatalk
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Hi Guys
          Thank you for the update it's nice to hear the outcome.
          Regards Mark
