Canon IPF 755 Plotter Hardware Error 03130031-2618
  • Doug James
    • Jan 2012
    • 935
    [Dead] Canon IPF 755 Plotter Hardware Error 03130031-2618
    Canon IPF 755 Plotter Hardware Error 03130031-2618, I got this error then put a new printhead in and then "Right after power up got a "Need to change printhead" error. One thing I notice here is that there are large gaps of air by the printhead clear tubes. In the book it says to check the power supply unit. I am new to plotters and wanted to get a second opinion. So should I replace the Power Supply QK1-5141-000 ?. Thanks so much for any help !!!
    • 23008
    Re: Canon IPF 755 Plotter Hardware Error 03130031-2618
    For me, it was the printhead.
    This is the advice I got here at Copytechnet:
    VH high voltage error. In order of likelihood can be caused by the printhead (60%), main board (30%), head relay PWB/carriage relay PWB or ribbon cables (10%).
    First replace print head (2251B003AC). Second check ribbon cables and connections. Third replace main board (QM3-3215-000). Fourth replace carriage assy (QM3-3330-000) or separately carriage relay PWB (QM3-3221-000) and head relay PWB (QM3-3229-000). Fifth replace carriage ribbon cable.
