4045 registration settings changing
  • repeatcopiers
    • Sep 2008
    • 591
    Customers 4045 was cutting off parts of copies and scans. Tech adjusted registration speen and doc stop settings in service mode and had it scanning correctly, then a few scans later it started doing the same thing. It isn't storing the settings for any length of time. Would this be the reader controller pcb?
    Re: 4045 registration settings changing
    If you do 10 scans to a computer is the registration off ?
    If you do 10 copies is the registration off ? if so registration clutch or thereabouts.
      +1
      • tsbservice
        Field tech
        • 8016
        Scan/copy from DF or glass?
        Agree on registration clutch especially if it does it from glass AND incorrectly placed images are moving on paper in subscan direction.
        • 20 year tech
          • May 2014
          • 577
          Have you changed or cleaned the feed rollers ? I would start there before ordering a RCON or any other items. Stick to the basics first.
            • 16391
            He's saying that he adjusted the registration timing and the machine isn't storing the setting.
