Canon IR Advance washed out copies on 1 side when duplexing
  • CopierChick
    • Aug 2012
    • 84
  • M94
    • Jul 2020
    • 158
    Re: Canon IR Advance washed out copies on 1 side when duplexing
    Originally posted by CopierChick
    I have a Canon IRA 4225 that has started making washed out copies (and prints) but ONLY when using the duplex. As you can see I’m the pix one side looks good but the other is super washed out. I numbered the pages as they were in the document feeder and the paper that was on top in the doc feeder is the one that came out washed out.
    I also tried to do a graduation adjustment but it kept saying I needed to out the paper on the glass properly and I was never able to completely finish it even though I got as far as the last sheet it printed needing to be scanned. I included a pic of that sheet also.
    the machine has leas than 70k pages and is in a clean office setting.
    all suggestions appreciated!! TIA
    UPDATE: I am trying to upload pix but having an issue. Will be able to add them soon hopefully
    It's weird that it only shows up when duplexing, but if you're having trouble with the images uploading you can post a link to something like google drive. Or flickr is free image hosting that won't reveal your email address if you prefer.
    Edit> You say when duplexing but do both sides come out light or just the side that was duplexed? Edit 2> Your title clearly says one side, my bad.
    • CopierChick
      • Aug 2012
      • 84
      Pix attached
        • 14743
        Strange problem, indeed.
        The blacks looked washed out. I'd say DV or moisture in paper but if it's only doing it in duplex... that rules that out.
        What kind of paper are they using?
        Can you print out some solid black pages?
        Have you tried printing on both sides of the page using the bypass tray? If so, what does the 2nd side look like?
        • CopierChick
          • Aug 2012
          • 84
          when I take 2 good pages and put them in the doc feeder and use the duplex to make this 2 sheets become 1 sheet front and back then 1 side looks good but the other side looks all washed out. The pix with the font lists were what came out front and back. Btw, the customer says this also happens when they print double sided pages.
          If you do single sided copies and prints they look great but double sided pages always have 1 side all washed out and 1 side great
          • CopierChick
            • Aug 2012
            • 84
              • 14743
              Understood. I've seen cheap paper do some strange things. I'd rule that out 1st. Take some good paper with you.
              Also, make a single side copy like you'd normally do and then put that page in the bypass and print on the 2nd side. I'd be curious to see if the problem goes away.
              PS - Is this a single pass doc. feeder? I'm not familar with this brand.
                • 14743
                the paper they are using in a basic sams club brand which I also use and have no issues with
                i am no longer at the customers but can definitely try the solid blacks next visit
                i tried printing on both sides using both paper trays and even changed the paper direction in each tray and had the same exact outcome but I didn’t try the bypass, do you think that would make a difference?
                It would eliminate the the possibility that the paper is somehow curling when it goes thru the switchback gate when duplexing. That's my line of thinking. But again, I don't work on Canon.
                • CopierChick
                  • Aug 2012
                  • 84
                  I has the customer try a brand new unopened ream of HP branded paper made for Copiers and it made no difference.
                  I also had the customer run the pages thru the bypass like you would normally if making a double sided copy and it made no difference. I then had them run the page as you suggested by running one side and then putting it in the bypass and the copies come out good. But I figured that would happen since the copier does great when doing single sided pages or pages.
                  • CopierChick
                    • Aug 2012
                    • 84
                    • tsbservice
                      Field tech
                      • 7635
                      I also don't normally work on Canon brand but many MFPs have different settings for second side transfer voltages. Look for this settings in service manual and try to increase value if possible. Test what will happen if you select thick paper instead of plain?
                      • t85ster
                        • Mar 2015
                        • 39
                        Extremely damp paper will cause this type of problem. First pass thru is washed out, second pass thru is good because paper dried out during the fusing process during the first pass.
                        • CopierChick
                          • Aug 2012
                          • 84
                          i wish damp paper was the issue but we have tried a brand new ream of HP branded copy paper that was sealed and we had the same issue
                          • Venom
                            Technical/IT Support
                            • Nov 2009
                            • 765
                            This looks like a drum issue, I would try another drum.
                            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                            • charm5496
                              • 2387
                              What is the condition of your transfer roller? Also take a look at the attached screenshot. It describes a similar issue to yours.
