CANON iR2200 Error code E000350-001
  • PhilGDS
    Hello,
    Can anybody help me with error code E000350-001 of a iR2200 CANON copier?
    Thanks in advance . Regards. Philippe
  • kwazimoto
    • Jan 2007
    • 199
    E350
    r u sure of the code it is not in a canon service manual.. will check on line and get back to u..
    • kwazimoto
      • Jan 2007
      • 199
      E350
      Ok found it it is a fault with the serail number PCB..
      check connector J1023 on main controller...
      If you changed boards that cvould be the problem also...
