Cano IRA c2225 error code E000070-0000
Re: Cano IRA c2225 error code E000070-0000
Clean the detection sensor, it reads the white patch on the belt.
E070 0000 Title ITB rotation detection error
Description The sensor fails to detect although it passes through the mark
on the ITB for the specified time (ITB is detected as not rotating)
Remedy The HP mark is at undetectable state, ITB Top Sensor error, or
error in the coupling between the ITB Unit and the ITB Drive
1. Check if the ITB is driven.
When the ITB is driven
2-1. Check soil of the HP mark on the ITB Belt
3-1. Check if there is a scar at the edge of the ITB
4-1. Use your hand to check if the shutter of the Registration
Patch Sensor Unit can be open
5-1. Check for soil on the window of the Patch Sensor (UN43/
UN44)
6-1. Check movement of the Registration Shutter Solenoid
(SL02)
COPIER > FUNCTION > PART-CHK > SL to move SL02
7-1. Check the harness/connector between the DC Controller
PCB (UN09/J12) and the Patch Sensor (UN43/J4007, UN44/
J4006)
8-1.Replace the Registration Patch Sensor Unit
9-1 Replace the ITB Unit.
10-1. Replace the DCON
When the ITB is not driven
2-2. Remove and then install the ITB Unit
3-2 Replace the ITB Unit.
4-2. Replace the Main DriveLet us eat, drink, and be merry, because tomorrow we may die!
