IR 2520 jam error
  • anas.agha
    • Aug 2023
    • 16
    IR 2520 jam error
    Hello
    when power on printer, dirctly a paper jam error appears without any sound from the printer gears and nothing moves, just the scanner sound check
    I check everything no paper or anything stuck inside... I need detail datasheet .
  • Brian8506
    • 1621
    If it has a finisher check on top of it where the 3 way unit is. Paper can get up there when doing double sided and it’s difficult to see.
    • COPIERTEC ASSOCIATES
      • Aug 2011
      • 276
      check the sensors and sensor flags and possible wiring connectons
      • anas.agha
        • Aug 2023
        • 16
        thanx all , not has a finisher
        i clean and check all part and disassemble fixing assymble and check all gears move when try manually.
        but still same problem
        • copier tech
          • 7921
          Originally posted by anas.agha
          Hello
          Check the lower right door guide, had once once this was broken / loose blocking the sensor arm showing a permanent jam like yours.
          • ReproKev
            • 259
            Check the jam code in service mode. It'll tell you the exact sensor reading the jam.
