Canon IRADV C5250 Hard Drive Format Error
  • ekylin
    • Oct 2024
    • 10
    About Canon IRADV C5250 Hard Drive
    I have a Canon C5255 machine. The old hard drive failed to boot the machine with error “E602-0001”
    I tried to replace a new hard drive (WD 500GB), inserting a FAT32 flash drive with iAC5255 folder system files, but when formated the hard drive, it prompted
    "[ERROR]. Cannot find format file
    hdd format ... Error"
    I had changed the smaller flash drive and hard drives, still same error.
    What's the format file? Any one can help or send the format file?
  • ADV COPIER
    Pemain
    • Nov 2022
    • 207
    Check the firmware file correct
    Let's Drink our Coffee
    • ekylin
      • Oct 2024
      • 10
      Yes, got iAC5255 foler in flash drive, but no ***HDformat.ift. Is it short this file made the file error?
      • ADV COPIER
        Pemain
        • Nov 2022
        • 207
        Yes
        • ekylin
          • Oct 2024
          • 10
          Could you send one copy the format file? Thanks
          • ekylin
            • Oct 2024
            • 10
            ekylin@sina.com
            • ADV COPIER
              Pemain
              • Nov 2022
              • 207
              File send
              • ekylin
                • Oct 2024
                • 10
                File Received. Thanks ADV COPIER. I go to try again now.
                • ekylin
                  • Oct 2024
                  • 10
                  Just tried, error message changed.
                  HDD Format. Do not cut power.
                  HDD Formatting(ALL)...Error
                  • ekylin
                    • Oct 2024
                    • 10
                    I have replaced a new hard drive WD 500GB
                    • ADV COPIER
                      Pemain
                      • Nov 2022
                      • 207
                      Maybe hdd not supported or your firmware is corrupted
                      • ekylin
                        • Oct 2024
                        • 10
                        Is it possible to modify the HDDDescriptor(Format File) to fit the format of new hard drive?
                        • ADV COPIER
                          Pemain
                          • Nov 2022
                          • 207
                          No
                          • ekylin
                            • Oct 2024
                            • 10
                            Could someone provide an HDD Descriptor (HDformat file) for WD 500GB?
                            • ADV COPIER
                              Pemain
                              • Nov 2022
                              • 207
                              Try use this model
                              - Toshiba MK1676GSX
                              - Toshiba MK16GSX
                              - Toshiba MQ01ABF032
                              - Hitachi 5K320-160
                              - Hitachi Z5K320-160
                              - Western Digital WD-1600BUCT
                              - Western Digital WD-1600BEVT
