Canon ir2870 jam problem
  • comaiel
    • Oct 2020
    • 18
    [Jamming] Canon ir2870 jam problem
    Hi, why is the paper jammed in A4 format while A4R is okay?
    I tried from all the drawers and it doesn't change. Obviously the selector and the card are set right ...............
    • 23006
    Re: Canon ir2870 jam problem
    Is it obvious? Can you be more specific? Paper size and orientation maybe? =^..^=
    • comaiel
      • Oct 2020
      • 18
      the format and orientation are right. only if I move to A4R I have no jams
        Then obviously the settings aren't correct.
        • Brian8506
          • 1664
          A jam code would help
          • Brian8506
            • 1664
            Do you have the dial on the paper tray set to the correct size?
            • comaiel
              • Oct 2020
              • 18
              • Brian8506
                • 1664
                • comaiel
                  • Oct 2020
                  • 18
                  Thanks were the dumper pads
