[I-SENSYS LBP613cdw] Error E015-0000, idk why?
  • Fujisan
    • Dec 2024
    • 1
    [Error Code] [I-SENSYS LBP613cdw] Error E015-0000, idk why?
    What is happening?
    (1: Upon startup, the printer spools up for a few seconds before...balking, for lack of a better word, stopping dead what it was doing in it's tracks and displaying the error message.
    (2: It used to, whenever it recieves and executes a print job, spin up, pull up a sheet of paper, and once it has drawn the paper past the first set of rollers, balk, stop dead in it's tracks and refuses to go any further. Upon restarting, it shows a 'paper jammed' dialog; when the back cover is opened, however, the paper is only barely visible (less than a milimeter of paper stuck out of the ridge). It poked out so little that only by removing the paper tray was it possible to remove the paper itself.
    (3: When paper was fed into the upper tray, it would do literally nothing; after spinning for what appears to be 'X seconds', it immediately halts and displays the error message.
    (4: It displays (currently still is) the E015-0000 code on the screen, prompting to turn the printer off and then restart it; however, even after doing it, the issue still persists.
    (5: Attempting to initiate Cleaning the Fixing Assembly displays a "Cannot Clean" dialog
    What have I tried to try and solve the problem? (and to no avail)
    (1: Restarting the printer (no luck)
    (2: Unjamming the paper and letting the printer run again (it simply repeats the cycle)
    (3: Cleaning all the rollers and letting the printer clean the ITP transfer belts (still no luck)
    (4: Using new and fresh paper to prevent jamming (it phamtom jams, not snagging on something)
    (5: ​Dismantling the thing (a loose spring was found in the Development motor gearbox and fixed, to no avail)
    I'm at my wit's end as to what to do, and some help would be greatly appreciated. I'm pretty sure solenoids and/or springs acting up are not issues since the problem persists even after the loose springs had been put back in place...what do you guys think is the reason?
    Thanks in advance for your responses.
