c5255 how to configure a J1 booket finisher
  • chuck5255
    • Oct 2021
    • 5
    I acquired a c5255, could someone please guide me in the right direction on how to configure a J1 booket finisher.
    thanks in adavance
    I have the following error e000720-0001
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4961
    Re: c5255 how to configure a J1 booket finisher
    No configuration required. Error code is because probably the firmware from the finisher is not compatible with the printer.
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • chuck5255
      • Oct 2021
      • 5
      Thanks for your response. The firmware was updated before the finisher was installed. I attempted to update firmware with no luck. Is there a work around this?
      thanks in advance.
      • zoraldinho
        • Mar 2008
        • 4961
        Did you put the printer in download mode and with usb overwrite all?
        • chuck5255
          • Oct 2021
          • 5
          I will search the site on how to do it and post back. Thanks
          • chuck5255
            • Oct 2021
            • 5
            I have been unsuccessful finding material on putting the printer in download mode. could please share how to put in download mode.
            thanks
            • chuck5255
              • Oct 2021
              • 5
              can anyone guide me on the step to update firmware thanks inadvance
                • 22808
                Should be in the service manual.
                Surely you have one
                Right?
