IR-ADV 8505 black lines
  • gksapple
    • Apr 2014
    • 116
    [CQ] IR-ADV 8505 black lines
    Hi
    symptoms : Black lines on the images.
    action taken : cleaned the laser unit ,primary and pre transfer contact point ,dv drive assy ,drum drive assy and re re fixed .
    1. Replaced primary charging unit ,pre-transfer corona ,etb belt unit ,dv unit, drum unit ,ap kit , developing drive assy ,drum drive assy .
    2.replaced developing hvt ,etb hvt .but still issue remains.
  • Hishamawada
    • 174
    Re: IR-ADV 8505 black lines
    Hello ,
    What is the paper direction ? And can u please make a test on A3 or larger
    Sent from my M2101K6I using Tapatalk
    • gksapple
      • Apr 2014
      • 116
      Originally posted by Hishamawada
      Hello ,
      hi
      A4 is the feeding direction.
      • hutmah
        • Sep 2017
        • 19
        • gksapple
          • Apr 2014
          • 116
          hi
          As You mentioned ,adjusted the belt speed ,lines disappeared. Issue solved .
          adjusted value -25
          thank a lot
