Canon iR-ADV C5735 - How do I enable Store function?
  • Jaywalker79
    • Jun 2022
    • 1
    [Misc] Canon iR-ADV C5735 - How do I enable Store function?
    Hello Everyone
    I've got a Canon iR-ADV C5735, in the Access Received/Stored files on the RUI, there is only the option for Fax mailbox. Does anyone know how to turn on the mailbox functionality to allow print output to 'Store'?
    Thanks in advance,
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5001
    Re: Canon iR-ADV C5735 - How do I enable Store function?
    (1)
    Press (Settings/Registration) → [Preferences] → [Display Settings] → [Store Location Display Settings].
    (2)
    Select [On] for [Memory Media] → press [OK].
    [Use MEAP Driver for External USB Device] is set to 'Off'.
    (1)
    Press (Settings/Registration) → [Preferences] → [External Interface] → [USB Settings] → [Use MEAP Driver for External USB Device].
    (2)
    Select [Off] → press [OK].
    <Use Print Function> is set to 'On' in [Use Scan/Print Function].
    (1)
    Press ((Settings/Registration) → [Function Settings] → [Store/Access Files] → [Memory Media Settings] → [Use Scan/Print Function].
    (2)
    Select [On] for <Use Print Function> → press [OK].
