Canon bearing for IR6265 fuser pressure roller
  • tonerhead
    • Sep 2009
    • 582
    I am rebuilding an IR6265 fuser. There is nothing wrong with the heat roller or pressure roller. It failed because the back pressure roller bearing seized. Parts catalogs only show the pressure roller with bearings. Has anyone found a bearing that will work rather than replacing the assembly? I would assume this is cheaper than the assembly so that's why I'm asking.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
  • wassem
    • Aug 2012
    • 164
    Re: Canon bearing for IR6265 fuser pressure roller
    the pressure roller and the bearings of canon 5055 are the same
    • tonerhead
      • Sep 2009
      • 582
      Thank you.
      • Brian8506
        • 1634
        I don't think they sell those bearings. They stopped presumably because when the bearing seized it had already damaged the fuser roller shaft and whole roller needed to be replaced. Maybe an aftemarket bearing is available
        • COPIERTEC ASSOCIATES
          • Aug 2011
          • 277
          The bearings are readly available on market in my country
